Cam timing help needed
Old Feb 14, 2009 | 11:18 AM
Imo000's Avatar
Default Cam timing help needed
I ran into a little snag with my buid last night. I think I have it all firgured out but want to double check before the valve cover goes on.
This is what happened:
After isntalling the cams, next in line was valve adjustment. This is when things started not making any sense. So after a good look and some thingking, it was apparent that the two cams were 180 degrees out (had the sprockets on the wrong location). The timing marks on the sprockets were dead on but the cams were not.
Does anyone have a diagram or picture of the cams where the crank is at "T" and the cams are at the "EX" and "IN" spot? I would like to compare the cam lobe directions to verytfy it with mine. Only need the direction of the ends, as that's sufficient enough for me.
Thanks for any help!
Imre
Old Feb 14, 2009 | 02:15 PM
Shadow's Avatar
Best I can give you is the link to the manual:
http://myweb.tiscali.co.uk/midlife/i...ice_Manual.pdf
as I recall it has good pics and a full writeup.
Old Feb 14, 2009 | 02:22 PM
DragonCBR's Avatar
I imoo if you do a search for camchain, you should find the info with picture, i rememeber a few threads with pictures...and they are very torough.
Old Feb 15, 2009 | 02:46 AM
Naga_Thai's Avatar
Photos here any help?...
http://gonzo-home.com/cbrmaint.htm#Valves
https://cbrforum.com/forum/showthrea...lve+Adjustment
Old Feb 15, 2009 | 06:55 AM
Imo000's Avatar
Thanks for the help!
I was using the manual (have it printed out) but got a little bit ahead of myslef. Installed the cams before setting the crank to TDC. Because of this and the fact that the cam caps were installed, I lost the refernce point that the manual mentions, (casting marks on the cams). I do have the starter fuse out, never truned the engine over by anything but by hand, and and the valves never contacted the pisotns. I've done work like this many times on cars so I know not to crank the engine over untill its first done by hand. Most of the times, manufacturers would design parts so they can only go together one way however in this case, Honda didn't do that with the cam sprockets and sure enough I mixed it up.
R1der02
Oct 16, 2021 06:52 PM
phack
F2 Tech
Jun 9, 2012 11:38 PM
tplatcbr
Jun 3, 2010 02:54 PM
drpitlo
May 23, 2009 06:38 PM
stoneguy1037
Jul 25, 2008 05:37 AM
