cam bearings
Old Mar 27, 2011 | 04:57 AM
Aussie Johnno's Avatar
Ride of the Year ... Just Ask The Boys
Can someone please explain what
"line bored and honed" means
In simple english, so that i, in my feeble mechanic mind can understand.
Does it mean as the engines are assembled the cam caps are inserted the drilled in place.
Not sure
Aussie Johnno
Old Mar 27, 2011 | 04:43 PM
DRam's Avatar
Very Honorable Most Senior Member :)
You have it about right. The cam caps are installed, torqued, and then bored and honed to spec. Then the caps are removed, cams installed, and everything is bolted together.
As I understand it the process is used to make certain the bearings are perfectly in line as well as within specs.
Old Mar 27, 2011 | 05:13 PM
Imo000's Avatar
DRam has it right. The bottom end bearings (conecting for and main bearings) are done this way too.
GregVhen
Aug 25, 2012 02:19 PM
segraves1
Jun 30, 2011 12:51 PM
Will.Bass
Apr 11, 2011 12:27 AM
skitz323
Sep 9, 2010 03:11 AM
Harry_T_Hamster
May 25, 2008 05:22 AM
