bearings
Old Apr 8, 2011 | 11:22 PM
Will.Bass's Avatar
Default bearings
so as some of you know, ive been completely re-doing my front end lately. the time has come to start re-assembling. (fork bridge, triples..) repacked my bearings. greased up my bearing races. did an initial torque (18lbs) and the final torque (22lbs). low and behold. i have very defined areas of hang..dis assembled, re cleaned. and i can barely see notches in the frame races.
SO..i guess i get to spend either moree tim, money, or both, doing bearing work.
so bring on the suggestions! should i try to smooth out the 2 races? should i replace them? who has cheap steering bearings? i saw some on ebay, but they are not factory or even alike. they are the newer cone taper style. does anyone have these in their bike? how did/do they work?
Old Apr 9, 2011 | 02:46 AM
kerosene's Avatar
go buy oem, only way to go when it comes to steering bearings.
Old Apr 10, 2011 | 08:19 AM
jeason15's Avatar
agreed!
Old Apr 10, 2011 | 10:22 AM
billetproof97's Avatar
I bet they will be pricey too from a local cycle shop. But steering components are not something to skip out or go cheap on. I hope they are decently priced
Old Apr 10, 2011 | 10:33 AM
Will.Bass's Avatar
im expecting somewhere in the 40-50 dollar range. lucky me. my local honda has the exact same days and hours that i work...so who knows when ill be able to get this stuff...
Old Apr 10, 2011 | 10:55 AM
jeason15's Avatar
here are the parts you will need. items 4, 5, 8, 9 and 10. about 90 bucks all together.
World of Powersports' 1996 Honda Street Bike CBR600F3 SUPER SPORT Parts List
Old Apr 10, 2011 | 11:14 AM
kerosene's Avatar
Go buy it from ronayers
63.00 + 8ship
Old Apr 10, 2011 | 02:08 PM
Will.Bass's Avatar
yea, thats too expensive. my local honda actually price matches most of the time. i normally get the prices from ronayers.
total for all of those there comes to 63.5.
Ronayers.com Microfiche Honda>Motorcycle>1996>CBR600F3>STEERING STEM
much better, tho i dont plan to replace the seals. mine are still good and soft. only question is do they come with upper AND lower races? i cant even find them in any fiches.
Old Apr 10, 2011 | 02:14 PM
kerosene's Avatar
You reuse the races.
Replace the seals, if you don't the wear on the bearings could potentially be faster... and they're cheap, so do it.
Old Apr 10, 2011 | 02:19 PM
Will.Bass's Avatar
the RACES are whats causing my problems. the bearings are fine. the RACES have divots from an accident prior to me owning the bike..
