Braking Issue
Old 03-25-2008, 06:57 AM
CBRdruid's Avatar
Default Braking Issue
I noticed since I bought my Hurricane, when I'm coming to a stop, just as I'm about to completely stop, the front brake pulses...alot. Could I need new pads as the guy said they were new and with no downtime from work, I havn't had a chance to check. If not a pad issue, could it be something more serious?
Old 03-25-2008, 07:03 AM
Default RE: Braking Issue
How's the color of the brake fluid ? Brown colored fluid means moisture in the brake fluid. It changes the consistancy of it and can give a kind of jerky grabby feeling.
Old 03-25-2008, 07:10 AM
CBRdruid's Avatar
I'll check when I get out for lunch. Hopefully it's something easy like that. I was planning on changing fluids this weekend. Guess I'll be starting MUCH earlier. Thanks for the idea.
Old 03-25-2008, 09:16 AM
cbroar's Avatar
Sounds like either warped discs or sticking pistons.
Old 03-25-2008, 10:39 AM
Shadow's Avatar
I've had warped discs, and you'd feel the vibrations right through the speed range, not just at low speed.....I'm with Idodirt (Hi Bill) on this one...change the fluid to dot 4.
Old 07-22-2008, 06:25 PM
bruiserc's Avatar
Did you ever get the problem fixed.
Old 07-22-2008, 07:09 PM
DragonCBR's Avatar
Ok i am going to sound redundant, wheel bearing, before mine let go i gcould feel the brake pulsing... just my two cents!
have a good day!
Old 07-22-2008, 07:33 PM
bicklebok's Avatar
My bike did this too. I changed the fluid and pads(because the pads were worn) and it still did it. The owners manual, or maybe another manual I read, said that if it does this, check the tightness of the bolts on the linkage on the front wheel. One in particular.(Just check them all) I checked it and it was loose. After I tightened it the problem was gone. I did talk to a motorcycle mechanic several weeks ago and he said a wheel bearing would cause the same problem.
Old 07-22-2008, 07:45 PM
bruiserc's Avatar
The reason I asked was could it have anything to do with the Anti Dive Case. I noticed that the brake assembly moves back and forth when you move it with your hand on the left side where the ADC is but the right side assembly will not move. By the way I own a 87 Hurricane.
neoxaero
05-01-2012 07:20 PM
sony224422
03-27-2012 08:17 PM
CBRdruid
03-25-2008 06:57 AM
StangLou
09-01-2007 08:49 AM
1badcbrf4i
01-29-2006 01:00 AM
Quick Reply: Braking Issue
