Braking issue
Old Jan 28, 2006 | 02:13 PM
1badcbrf4i's Avatar
Default Braking issue
This issue RARELY ever happens. What happens is, if im trying to break too hard i suppose, the chain starts to skip, i dont know how else to explain this. It just sounds really bad, and the chain basically skips until i stop, and then everything is fine again. Could this if i used too much rear break? or do u think my chain is too loose?
Old Jan 28, 2006 | 08:20 PM
Tahoe SC's Avatar
Default RE: Braking issue
your chain won't skip unless it's too loose. check the tension.
if it's a chattering from the front like the chain is loose, it's somewhat normal. you just need to do your suspension.
so i really don't think it's your chain mang...
Old Jan 28, 2006 | 08:44 PM
1badcbrf4i's Avatar
how tight is a chain supposed to be...how can you tell if its tight enough
Old Jan 29, 2006 | 12:17 AM
doncollins's Avatar
Retired Administrator
You should have about an inch of play in it...
Old Jan 29, 2006 | 01:00 AM
kiggy74's Avatar
You should have an inch of play in the middle of the chain.
In addition, you should also check the teeth on your sprockets to make sure they aren't worn. This can happen over a long period of having a loose chain.
neoxaero
May 1, 2012 07:20 PM
sony224422
Mar 27, 2012 08:17 PM
CBRdruid
Jul 22, 2008 07:45 PM
CBRdruid
Mar 25, 2008 06:57 AM
StangLou
Sep 1, 2007 08:49 AM
