Braking Issue
Braking Issue
I noticed since I bought my Hurricane, when I'm coming to a stop, just as I'm about to completely stop, the front brake pulses...alot. Could I need new pads as the guy said they were new and with no downtime from work, I havn't had a chance to check. If not a pad issue, could it be something more serious?
RE: Braking Issue
My bike did this too. I changed the fluid and pads(because the pads were worn) and it still did it. The owners manual, or maybe another manual I read, said that if it does this, check the tightness of the bolts on the linkage on the front wheel. One in particular.(Just check them all) I checked it and it was loose. After I tightened it the problem was gone. I did talk to a motorcycle mechanic several weeks ago and he said a wheel bearing would cause the same problem.
RE: Braking Issue
The reason I asked was could it have anything to do with the Anti Dive Case. I noticed that the brake assembly moves back and forth when you move it with your hand on the left side where the ADC is but the right side assembly will not move. By the way I own a 87 Hurricane.
neoxaero
05-01-2012 08:20 PM
