Bike is struggling to start...
Old 11-23-2008, 05:01 PM
stuconz's Avatar
Default RE: Bike is struggling to start...
ORIGINAL: TimBucTwo
I would not rule out the R/R....
thanks for the tips. I'm picking up a fully charged new battery tonight, so will run these tests on he original battery to see what the result is. My charger is only acheapie from the WhareHou, and only indicates when it is charged.
As an aside, I cleaned out the carbs yesterday, it fired up ok. I kicked it over this morning and it fired up pretty quickly. I stopped at the servo for gas on the way to the orifice, and it took ages tostart again...
Old 11-23-2008, 05:11 PM
stuconz's Avatar
So, the mantra made to all newbies is to search the forums first. I admit, I didn't do that properly. I have been referred to this thread which sounds like exactly what's happening to my bike.
https://cbrforum.com/m_382825/tm.htm
Still, I'll exhaust all other avenues first before trying this scenario...
Old 11-24-2008, 01:33 AM
stuconz's Avatar
Well, the brand newYuasa went in,but the starting problems still exist. So now I've got a strong indication of what the problem is, thats my nextSaturday sorted. I'm going to swap the plates around first up, andif still no joy, I'll be buying a newdamperset for christmas...I'll update this thread when its all done.
Thanks for all your feedback, tips and ideas.
Hat tip to you all.
[sm=bling.gif]
Old 11-24-2008, 03:57 AM
Shadow's Avatar
There was a complete starter clutch on e-Bay a week ago - I'll see if I can find it.......
Here you go 3 days left, 40 pounds asked, no bids yet, brand new.....
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=280286459526
Old 11-24-2008, 04:12 AM
Bazman's Avatar
Hey Shadow.
It'll be the Alt damper (which gets confused with the sterter clutch)that causing the grief, as wasmy baby's prob.
Haven't seen one of those in your travels have you???
None avail in NZ and the one I picked up was a back ordered one that the couldn't return..
Old 11-24-2008, 06:02 AM
Shadow's Avatar
Only stator part I've seen is a complete stator cover for $50.........
It's an alternator on a car, stator on a bike, methinks.....
I've never seen any stator plates........
I'll have a search and see what can be dug up......
Old 11-24-2008, 06:11 AM
Shadow's Avatar
Here're all the parts that fit on the stator shaft, with a pic attached :
QUANTITY REF# PART #REQ YOUR PRICE
01 BASE, ALTERNATOR
11102-MS2-610 001 $57.44
[hr] >
02 GEAR (46T)
28110-MM5-010 001 $85.74
[hr] >
03 COLLAR
28115-MM5-020 001 $14.00
[hr] >
04 CLUTCH, STARTER
28125-MS2-613 (replaces28120-MS2-611) 001 $129.53
[hr] >
04 CLUTCH, STARTER
28125-MS2-613 (replaces28125-MS2-612) 001 $129.53
[hr] >
04 CLUTCH, STARTER
28125-MS2-613 001 $129.53
[hr] >
05 DAMPER, ALTERNATOR
28130-MS2-610 001 $99.95
[hr] >
06 DISK, SPRING
28151-MM0-003 002 $7.12
[hr] >
07 CHAIN (70L)
28161-MM5-013 001 $71.54
[hr] >
08 TENSIONER, ALTNTR
28170-MM5-640 001 $85.95
[hr] >
09 GUIDE
28191-MM5-000 001 $29.31
[hr] >
10 ROTOR
30291-MS2-610 001 $10.45
[hr] >
11 GENERATOR, PULSE
30300-MW7-003 (replaces30300-MS2-600) 001 $41.48
[hr] >
11 GENERATOR, PULSE
30300-MW7-003 (replaces30300-MW7-000) 001 $41.48
[hr] >
11 GENERATOR, PULSE
30300-MW7-003 001 $41.48
[hr] >
12 NUT, FLANGE (12MM)
90234-MM4-000 001 $3.82
[hr] >
13 WASHER (20X37X2)
90404-KK0-000 001 $3.29
[hr] >
14 BEARING (17X40X12-U)
91006-HA2-008 (replaces91005-MM4-003) 001 $16.34
[hr] >
91006-HA2-008 001 $16.34
[hr] >
15 BEARING (25X30X20)
91106-ME5-008 001 $15.34
[hr] >
91108-634-961 001 $15.34
[hr] >
16 O-RING (100X2.2)
91303-PA9-004 (replaces91303-PA9-003) 001 $6.19
[hr] >
16 O-RING (100X2.2)
91303-PA9-004 001 $6.19
[hr] >
17 CIRCLIP (42MM)
94520-42000 001 $1.43
[hr] >
18 BOLT, FLANGE (6X14)
95701-06014-08 005 $0.82
[hr] >
19 *95701-06016-08
95701-06016-00 002 $0.82
[hr] >
20 BOLT, FLANGE (10X20)
95701-10020-08 Tell me what you need - www.Mrcycles.com has all the bits.
Old 11-24-2008, 06:34 AM
Shadow's Avatar
Alternator damper complete from Mrcycles.com at $99.95 - new.....
No 5 on the parts list ........
Old 11-24-2008, 06:11 PM
stuconz's Avatar
Is that in SA dollars?
Old 11-24-2008, 06:24 PM
stuconz's Avatar
ORIGINAL: stuconz
Didnt see the link. USD$99.95 works out to be about NZD$210+ about $30postage. New. Hopefully the one I've bought off Baz will do the job
Quick Reply: Bike is struggling to start...
