Bike starting
Old Mar 11, 2007 | 04:52 AM
MarkR's Avatar
Default Bike starting
How do you guy's starting your bike, rev wise
I had been starting it at low rev and build it up, but my car mechanic said that engine suffer from bad wear if started to slow and should be started at about 1500rpm
Old Mar 11, 2007 | 06:57 AM
R1000's Avatar
Default RE: Bike starting
I let the engine spinaround 1700rpmdirectly from start for about half a minute or whatever it takes to get the bike moving, and the choke leaver is disengaged as soon as possible (after 50 to 100 meters or so). The oil will warm up far quicker if the bike is driven. Then I let it cruise for a couple of minutes and keep it under 5 k rpm until fully warmed up. That will take about 10 km's. Some people let the bike warm up on fast idle, I don’t since thecylinder walls willthen be unnecessarywashed by gas. The important things are, like tour mechanic say, not to let the bike run on very low rpm cold, and that it is warmed up before gunned.
Old Mar 11, 2007 | 08:20 AM
collector's Avatar
Ditto.......... Well something along those lines............anyway, to start, if needed, always use your choke first, then ease it off as the engine warms up.......
Old Mar 11, 2007 | 09:39 AM
Trips's Avatar
I try and avoid long low rpm idle times as it means the oil is goign through the bypass in the oil filter instead of getting filtered due to low oil pressure at low rpm
Old Mar 11, 2007 | 09:54 AM
MarkR's Avatar
I never gun it until the temp is normal, I have seen old people rev the sh*t out of thier cars to warm them up, <dumb>
I avoid hills when cold.
But now I will be staring the bike at 1500rmp
Old Mar 11, 2007 | 10:35 AM
forx's Avatar
does anyone know if adding,say "slick 50" type teflon additives will mess up the clutch?.
i add this to all my cars as it coats the cams etc with teflon stuff and obviously cuts down on the wear when starting etc.
Old Mar 11, 2007 | 11:07 AM
mikekop's Avatar
October 2009 ROTM
Yes, it will for sure mess up the clutch! Even using "car oil" instead of oil recommended for motorcycles can mess up the clutch.
Theoretically you could take out the clutch plates, perhaps the whole basket, and then run the engine standing still, or, (not that I recommend any of this!) push it up in speed and then put it in gear, with the "slick 50" additive in the oil, and then after you feel it has been "coated", flush out the oil with the additive with new oil and also replace that oil with new when having reinstalled clutch. As you can imagine, this will be expensive and much work effort and will probably not be noticeable in wear or fuel consumption.
Old Mar 11, 2007 | 11:22 AM
forx's Avatar
figured as much,thanks mike.
dagg92
F2 Tech
May 17, 2012 05:55 PM
siksauce
Oct 24, 2008 09:22 PM
nick16
Oct 29, 2007 05:39 PM
mjflagg
Oct 2, 2006 05:46 AM
AGoodrich18
Apr 3, 2005 11:19 PM
