Avgas
Old Oct 14, 2023 | 04:15 PM
Jsceen's Avatar
Default Avgas
I am being told that a half avgas to regular 93 octane mix every once in a while is good for the CBR1000F. I was told that it will clean the jets and the carbs. Is this true? Since I like my bike, I am making sure before doing anything.
Please chime in.
Thnaks
Old Oct 14, 2023 | 04:52 PM
rockpool's Avatar
just use real carb cleaner additive. If Avgas (kerosine) dissolved varnish, then so would gasoline.
Old Oct 14, 2023 | 05:47 PM
Jsceen's Avatar
That is different than fuel injector cleaner right? I added fuel injector cleaner and the backfires were incredible.
Old Oct 14, 2023 | 09:57 PM
dannoxyz's Avatar
What cleaner did you use? Backfires means mixtures aren't burning properly.
Also AvGas is leaded petrol for piston engines with lower density and you'll end up with leaner mixtures that can cause damage. Jet-A and Jet-A1 is kerosene.
Best is PEA-based fuel-system cleaners that was designed with only that purpose in mind. Use a bottle every couple months to keep engine clean. Follow mixing instructions on bottle. One should treat about 3 tanks.
  • Red Line SI-1
  • Techron Concentrate Plus
  • 3M Max Strength Fuel System Cleaner #08814
  • Royal Purple Max Atomizer 18000
  • Gumout All-in-One (might be off list soon due to dropping levels of PEA)
Old Oct 15, 2023 | 12:40 PM
Jsceen's Avatar
Thanks! I'll let you know how it goes.
pgilmore
Alternative Parts
Nov 19, 2012 03:29 PM
outlawfox13
CBR1000F For Sale / Found
Jul 24, 2011 10:55 PM
Mako
Jun 3, 2010 08:42 PM
cdrewferd
Rides
Mar 26, 2010 04:06 PM
jpanside@gmail.com
May 23, 2009 09:54 PM
