For anyone planning on an 18 tooth up front
if ur goal to get 310 km top speed then use 13 teeth front and the biggest sprocket on rear but the only thing that u can not get more power in the first to 2nd gear but when u reach the 3th to 6th gear , u can feel the differences, its like u have nitro in ur bike... this is not good for short drag racing..
on
Raiden
Actually I think you mean
as big as you can go on the front ......which is 18
and as small as you can go on the rear ........which last I found was 38
(Smaller rear sure but you'll start sawing off your swingarm)
Makes for greatest TOP END speed.
Actually ..........it's a fact. Here's the JT Sprocket Gear Ratio Chart Attached
With respect, Raiden,you have the ratios backwards.........
bigger front and smaller rear sprocket gives you higher top speed, but less accelleration. Your 13 front would make the bike unrideable, (and I don't think it would fit anyway, as the chain angle would be too abrupt. I've dropped mine to a 15 front, and the bike became a wheelie machine) 15/46 is enough to drop GSX1000R's on accelleration.............but the top end drops down to about 200KPH
As for 300, I can vouch for 265 with 17/42 gearing, and I still had about 20 K's per hour left, so I guess under the right conditions, 300 would be possible, but you'd need lots of room................
