any way to clean the CCT??
hi can you clean the cct inside the engine? possible? probly a flush is in order? or the easiest way. desiel oil , atf, paintthinner, j/k
any ideas welcomed
any practicedd ideas with good results welcomed even more
any ideas welcomed
Hi Chris,
When I changed mine a couple of months ago, I put the old one upside down on the bench, and after a few hours all the muck dripped out. I think it would probably be OK to re-use, but I had the new one, so fitted it anyway.
Due to the location of it, I would say that in-situ cleaning is impossible (unless you turn the bike upside down!)
Cheers,
Rob
Cheers,
Rob
Cleaning it in the engine isn't really a good idea. You'd end up with all kinds of solvent and muck in the oil pan. Take it out, turn it upside down, pump it until nothing more comes out, then hold it in solvent and pump it some more. Then leave it sit overnight, drain it in the morning. I repeated that process until no more gunk came out when clean solvent was put in, then filled it with engine oil and reinstalled it. I then rode the bike for a while,took the CCT back out, threw it away and put a new one in. Problem solved. Somehave had good luck cleaning and reinstalling, I didn't.
ORIGINAL: DRam
Go to page 17 of the threads and look under engine flush. This is the method I used myself and was very successful with cleaning the cct and engine. All the rattles from the cct were taken away.
[sm=bounceybounce.gif]
ORIGINAL: DRam
Cleaning it in the engine isn't really a good idea. You'd end up with all kinds of solvent and muck in the oil pan. Take it out, turn it upside down, pump it until nothing more comes out, then hold it in solvent and pump it some more. Then leave it sit overnight, drain it in the morning. I repeated that process until no more gunk came out when clean solvent was put in, then filled it with engine oil and reinstalled it. I then rode the bike for a while, took the CCT back out, threw it away and put a new one in. Problem solved. Some have had good luck cleaning and reinstalling, I didn't.
ORIGINAL: WhiteHawk
How many miles did you have on your bike?
ORIGINAL: DRam
DRam
3 - 24 07 Oops - Went for a ride today and noticed the CBR is34,000 give or take. Blame it on old person memory.
