Alternator / stator needed
Old May 27, 2007 | 01:30 AM
Nevada Fred's Avatar
Default Alternator / stator needed
After fooling with this problem long enough it appears that the stator is faulty in some way. I tesrted the three yellow wires to ground one at a time and that was OK; I checked for continunity between the phases and that too was normal. I checked the phase detector circuit (black and white wires to alt.) and that was good. I did the A.C. output test and found one pair was only 20v A.C. the other two combinations 50.2V @ 4500 rpm. According to the fault guide the stator is faulty.
Anyone have a good used one or a price for new better than Ron Ayers (they were the cheapest I found @ $224.40 USD)? Honda p/n 31130-MS2-611, they fit 1990 to 1996 US models and a bunch of European versions of the same.
Any help out there in CBR land?
Thank you, Fred
Old May 27, 2007 | 03:16 AM
pacojoseph's Avatar
Default RE: Alternator / stator needed
1- E-bay, although it's a crapshoot as to how long you'll have to wait for what you need to pop up.
2- Find a local motorcycle salvage yard. Even if they don't have it, they're usually linked up
tootheryards and can locate what you need somewhere- theytypically charge 1/2 retail for used
parts.
3- Try these guyshttp://www.motorcycle-bike-parts.com/, although I have never used them and am not endorsing them in any way.
Old May 28, 2007 | 05:45 AM
brookslane's Avatar
make sure you check the rectifier too before you buy a stator....thats what i did and it was the problem....i got one of those for 100$
Old May 28, 2007 | 07:12 AM
Trips's Avatar
What about getting the Stator re-wound?
Shadow
CBR1000F For Sale / Found
Nov 1, 2012 11:21 PM
outlawfox13
CBR1000F Wanted / Swap
Apr 11, 2011 09:18 AM
Clorox09
Mar 18, 2009 07:31 PM
Steve_Cardiff
Sep 15, 2008 12:20 PM
bluRSXtypeS
Jan 17, 2006 06:43 PM
