Stator alternator cover
Old Jan 15, 2006 | 02:50 AM
bluRSXtypeS's Avatar
Default Stator alternator cover
I let my friend ride my bike and he layed the bike down and it cracked the stator cover. Does anyone know how much it will cost to buy a stator cover and if it's easy to replace on your own? Also will i need to replace the alternator or anything? There's oil leaking through the crack of the stator cover also. Thanks a lot.[sm=smiley19.gif]
Old Jan 15, 2006 | 02:53 AM
Advert25's Avatar
Default RE: Stator alternator cover
Well I just recently damaged my Alt. Cover as well and there is some oil leaking out of my cover as well. I spent all day today trying to track down a new cover. I never saw the price go over $60.00 I have a 2001 F4i and by what the Service Manuel shows, it looks really easy. Just unscrew the old one. Take the gasket off. Put a new gasket on and bolt it back on. Becareful because some oil will leak out, so make sure you fill it back up again before you ride it.
Old Jan 15, 2006 | 04:01 AM
mazdajoe's Avatar
I just bought a new one fron Honda last week. With a gasket and tax it cost 73.80.
Old Jan 15, 2006 | 06:07 AM
Thanks, you 2 were a good help. Does anyone know what kind of oil it is that's leaking? Is it just motor oil(if it is, do i just change oil agian)? Thanks.
Old Jan 15, 2006 | 06:29 PM
Fox's Avatar
Fox
ORIGINAL: bluRSXtypeS
Yes.
Old Jan 16, 2006 | 12:15 AM
kiggy74's Avatar
Make sure you read your manual chief. All these details are covered.
Old Jan 16, 2006 | 12:26 AM
pupdog_88's Avatar
you can get the stator cover off ebay for about 60.00 and it comes with a new gasket, to remove it just unscrew the cover and pull it lut it will be hard to pull it out because it is a really strong magnet, then unbolt the stator from the cover rebolt it to the new stator cover reinstall it on the bike and refill with oil, start bike check for leaks, and your good to go
Old Jan 16, 2006 | 03:24 PM
Fox's Avatar
Fox
Excellent opportunity to do an oil change. Just make sure you get a new gasket. I've seen "pros" put new heads, covers, etc. on their engines, and don't put new gaskets on. Bad idea. Spend the extra $5 because it's worth it.
Old Jan 16, 2006 | 07:35 PM
Thanks for your help everyone. I just ordered the part on eBay and it won't be coming in for a good week or so [sm=smiley6.gif].
Old Jan 16, 2006 | 10:40 PM
Advert25's Avatar
how much did you get it for? im on Ebay now looking around for one.
