Alternative alternator whats possible
I know anything is possible with some engineering but has anyone thought about whether an alternator from another model or make with built in regulator/rectifier could be made to fit. Grafting the cbr shaft onto another alternator and sorting the mounting
Whats possible
Its a bit like using different calipers by making a mounting bracket if you know what I mean (obviously a bit more difficult) Hypothetically why couldnt you use a gpz900r alternator (as my last project was using this bike ) which has a built in regulator etc. I have raised this as a debate as I have just started my project and like to digress from the norm. The things that raise questions are, 1, what sort of rpm does the cbr alternator turn at, 2 the mounting, 3 the cbr shaft from the alternator.
on
Hey:
I know on some Honda bikes a Kaw ZX7 alt is able to be grafted on but that is on the older CB F & CBX models. It may be a try, but with some clever maching or lucky trial and error most anything can be made to work, as you may well know. How many amps/watts do you want to support? The reason I ask is I have seen a few of these bikes hooked up to electric vest/seat cover/gloves/grips/camera/ usb devices & GPS and have no issues after a modern RET/REG upgrade to something BETTER than the OEM part. Just a thought. Good Luck and keep us posted, as I for one would consider doing this as well if I had the need.
DUB
DUB
hmm
08-28-2013 07:21 AM
Hondaspeedster
04-12-2011 01:10 PM
