94' carburator swap.
Old Dec 23, 2010 | 11:36 PM
LJ Harp's Avatar
Official CBRF Decal Man
Default 94' carburator swap.
I am working on a 94' 1000F It was obtained by a mechanics lean. I have some pictures of the carbs because the choke dosent work and by the way the airbox is set up I do not believe they are the original carbs. any information would be great because I do not know much about these bikes and you all are the experts.
Old Dec 24, 2010 | 12:10 AM
Sprock's Avatar
Not stock carb's , airbox has been butchered
Replace both.
Guessing I 'd say they maybe earlier Suzuki carbs
So your bike or "just" working on it ??
Old Dec 24, 2010 | 07:40 AM
LJ Harp's Avatar
Just working on it in a shop right now trying to.get it running and the see what I can do to get it. Its a way clean bike never been laid down
Old Dec 25, 2010 | 01:15 AM
tobiahr's Avatar
with the exception of the blue vacuum caps those look exactly like mine. off a 1994 cbr1000f...i will post more pics to my album if you need them
i had the same gunk around the airbox also. the airbox to carb gromet has two possible positions they can be installed and will leak air past the filter if not sealed
Old Dec 25, 2010 | 09:32 AM
TimBucTwo's Avatar
Yep! Same as my '94 right down to idle adjuster and the black goop.
I though someone was into mine but I guess the black goop is standard issue.
Old Dec 26, 2010 | 12:30 AM
LJ Harp's Avatar
So they are the right carbs and the airbox is standard like that
Old Dec 26, 2010 | 01:18 AM
tobiahr's Avatar
The consensus is yes. The air box is standard with all the gunk. The carbs may or may not be original (minor differences) but appear to be correct.
For further comparison see https://cbrforum.com/forum/album.php?albumid=2340 it’s all the pics I have of mine
Old Dec 26, 2010 | 09:44 AM
Shadow's Avatar
Carbs are the right ones for the year.
Make sure the vacuum hose on the left side carb is connected to the fuel petcock or you won't get fuel through.
A good clean and you should be good to go - judging from the state of the carbs they have been well cared for, or the bike hasn't done much mileage.
If you need a manual go to the Hurricane section and download one............
Oh and connect the choke cable or it won't start...........
Old Dec 26, 2010 | 10:46 AM
LJ Harp's Avatar
Hey thanks shadow bike has about 8,000 miles on it. Were just having troubles getting the choke to work the po took a bunch of hoses off. And when the shop manager asked him why he replyed with "weight reduction". So that he could go faster bahaha now we have to go through the whole bike and figure out what else he weight reduced
Old Dec 26, 2010 | 06:28 PM
kilgoretrout's Avatar
Administrator - Retired
Yep, everything looks stock to me as well. There were extra hoses on the california models.... that may be what all the vac capping is about. See if there is a PAIR sticker on the airbox and see if you can get an idea of the routing from that vac diagram.
And yes, I'd definitely clean them up and see about that leaky bowl.
Here is a picture of my carbs off a '95 Cali model with PAIR.
Notice the extra hoses and how I have them set up. This is how I did it so it would run correctly. Hope it helps some.
rjenkinscbr600
Dec 10, 2011 03:33 PM
landfast
Jun 13, 2011 05:56 PM
wjuranek2
Apr 22, 2008 09:02 PM
erknjerk
Sep 24, 2007 10:48 PM
Delmustator
Mar 24, 2007 01:27 PM
