93 cbr 1000f turn signal problem
Old 09-01-2007 | 08:34 PM
dewthedoo05's Avatar
Default 93 cbr 1000f turn signal problem
hi,
I wonder if anyone has encountered a problem like this:
up until last week, everything worked fine, but a couple days ago I discoved that I have a new issue with my turn signals.
My right front and rear both work correctly, but my left side ones are weird. the front left blinks twice as fast as it formerly did, and my rear does not blink at all.
Since i put on a fender eliminator kit on it a couple years ago, my first instinct was that there might be a crossed wire. I completely disassembled and unplugged all of my rear lights and signals, brake lights included, and still, the front left one blinked twice as fast, so nix on it being a rear wiring issue. My current belief is that it is the little black box(flasher) on the left side under my tail fairing that makes an audible clicking noise. I assume that is what controlls my signals, so I went to autozone and orielly's auto parts and noone could cross reference it. It says
MITSUBA
FR-3303
12.8v 85 c/m
23(21)w x 2+3.4(3)w
23(21)Wmax.4bulbs
JAPAN
A 799983DOT
anyone know if my assumption is correct, and if so, what would be the cheapest way to rectify this problem?
Thanks alot,
Nick B.
Old 09-01-2007 | 08:41 PM
Default RE: 93 cbr 1000f turn signal problem
hey moderator, i somehow made two identical posts. I dont know how to delete it, so can you delete this one, so i can use just the other one? thanks
Old 09-01-2007 | 08:49 PM
CBR1988's Avatar
Senior Member & Lord of the Odometer (300,000 Mles) & Counting
Hey:
You need a new rear light bulb. the rear indicator filament is burned out.
Just change it out and all should be good. Thats a normal indication to let you know the bulb
is burned out
Dub
RoosterF3
F2 Tech
14
04-10-2010 09:26 AM
Stugots
05-01-2008 03:51 AM
dewthedoo05
09-04-2007 09:32 PM
dewthedoo05
09-02-2007 06:27 PM
gotcharr
03-03-2006 11:48 PM
Quick Reply: 93 cbr 1000f turn signal problem
