1000f starting probs
Old 05-02-2008, 09:22 AM
regedit's Avatar
Default 1000f starting probs
hi guys took tank of to respray now wont start weak spark cheacked everythingcleaned carbs ect help
Old 05-02-2008, 09:45 AM
GILL's Avatar
Default RE: 1000f starting probs
So your getting lots of fuel to the cylinders okay? Start checking primary ignition voltages on the coil. From what you described earlier it sounds like it may still be a vaccuum leak either intake manifold side or a line. How do you know its a weak spark?
Old 05-02-2008, 09:56 AM
regedit's Avatar
turned engine with plug on top it looks weak would avaccuum leak cause it not to start not even try seemsto be getting pleanty of fuel thanks for your quick reply
Old 05-02-2008, 11:19 AM
GILL's Avatar
Ensure that its not flooded nowand cylinder wash didnt lower compression in the cylinders causing it not to start. I would take out the plugs, clean them up, have a very good close look at all vaccuum hoses and intake hoses coming from the carbs, ensure they are tight. Charge the battery good and try it again. It sounds like you have fuel and spark, so it obviously something you did while taking off the tank that your missing is my guess.
Old 05-02-2008, 11:37 AM
regedit's Avatar
just took plugs out no4 low spark no 1 no spark put no4 in 1low spark looks like plugs fooked
Old 05-02-2008, 11:40 AM
GILL's Avatar
I would pickup new plugs. They are cheap for this bike
Old 05-02-2008, 12:22 PM
regedit's Avatar
just changed plugs started irst press thanks
Old 05-02-2008, 01:01 PM
GILL's Avatar
Awesome..............
shigga
08-03-2011 12:02 AM
Biohazardous_Customz
03-03-2010 12:53 PM
504bully
12-15-2009 12:47 PM
Mo777
05-26-2009 07:08 AM
kmanracing24
05-11-2009 09:08 AM
Quick Reply: 1000f starting probs
