probs starting 954rr
Old Dec 14, 2009 | 11:45 PM
504bully's Avatar
Registered Users
Default probs starting 954rr
i got a 2003 954rr in pcs. and put back together when trying to start you can hear the starter gear turning and there is a popping noise from the fuse box/starter relay area need to get running any help would be great don't want to take to shop just put new starter gear on and new battery
Old Dec 15, 2009 | 12:47 PM
justasquid's Avatar
is it a single pop? Or is is a series of clicks that repeat very rapidly?
If its the latter, then the either battery is bad, or there is a short somewhere not allowing enough power to the starter relay.
Take a mulit-meter and measure the voltage at the relay. Crank it over, and see if it stays the same. It should be the same as at the battery, around 12.5-13 volts or so, if its not, then you probably have a grounding issue.
shigga
Aug 3, 2011 12:02 AM
Biohazardous_Customz
Mar 3, 2010 12:53 PM
Mo777
May 26, 2009 07:08 AM
kmanracing24
May 11, 2009 09:08 AM
regedit
May 2, 2008 01:01 PM
