900 & + Modifications This section is specifically for questions and advice pertaining to mods of the older models, 900 and up.
porting/milling head / cam timing question
Old Oct 26, 2007 | 07:27 PM
f1fever's Avatar
Default porting/milling head / cam timing question
this winter I'm planning on milling the head and porting it. when I mill the head is it going to retard my cam timing, if so how do I advance the cams? also any tips for improvements, like cam somewhere that don't cost $700 (ie regrinds)...also rev limiter..how do I remove/disable or increase the rpm? thanks!
-ps- can you make it so I can post using firefox?
Old Mar 5, 2008 | 11:18 PM
slimmcbr1126rr's Avatar
Default RE: porting/milling head / cam timing question
BE CAREFUL WHEN MILLING YOUR HEAD . MUST WATCH VALVE TO PISTON CLEARANCE.CAMS ARE EASILY DEGREED WITH ADJUSTABLE CAM SPROCKETS.A REAL GOOD RACE PORT ,POLISH AND VALVE JOB WILL SET YOU BACK ABOUT 1350 - 2250.00 DEPENDING ON WHAT PRODUCTS YOU DECIDE TO USE. ANY QUESTIONS FEEL FREE TO EMAIL ME
Old Mar 16, 2008 | 11:17 AM
Jarrod Franklin's Avatar
you should worry more about your compression ration rather than cam timing
[align=left] [/align]
"HONDA_BABY"
Feb 11, 2011 04:52 PM
Speedemon636
Apr 18, 2010 02:47 PM
R1000
Apr 9, 2007 09:44 PM
apexiex
Mar 3, 2006 12:51 AM
doncollins
CBR Zone
Jan 11, 2006 07:03 PM
