600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
Front End Swaps?
Old 12-13-2016, 03:08 PM
ShtBiker's Avatar
Default Front End Swaps?
I happen to have a 2007 ZX6R front end here and was wondering if it would fit on an F4i without any significant fabrication. Never done anything like this before so I'm mostly just asking out of curiosity.
Old 12-13-2016, 04:46 PM
Conrice's Avatar
I'm fairly sure it would. Go to allballsracing.com and look for conversion bearings and it might go right on. You can enter your bike's info and it will tell you what bike's front ends fit and if you need different size bearings. Stem needs to be the same length or you need to be able to press the F4i stem into the lower zx6 clamp.
You can find tons of info on stunt forums - I don't think any of those bikes have the original front ends on them...
Old 12-13-2016, 05:59 PM
ShtBiker's Avatar
Thanks for the link- that's a pretty cool tool. Unfortunately it didn't list that year of ZX as compatible. Oh well. I don't really have any reason to swap it.
Old 12-16-2018, 01:00 PM
If you already have the fork you want to use you can measure the stem (I.D. of the bearing on the new fork) as well as the O.D. of your existing bearing and order what you need. All ***** has helped me with this and there's lots of industrial bearing suppliers who can, as well.
While this modifications is usually possible, things to look out for are length of the new stem vs. the old and location of steering stops. These can be issues that will require a machinist to resolve.
johnnycrash
10-05-2020 09:40 AM
bullroarer
12-30-2017 08:40 AM
Will.Bass
04-11-2011 12:27 AM
StrikeAnywhere
11-28-2008 08:34 PM
oldcbr
03-28-2008 02:13 AM
Quick Reply: Front End Swaps?
