600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
98 GSXR FORKS on F2/F3..USD
Old Dec 10, 2018 | 11:21 AM
fatso1277's Avatar
Default 98 GSXR FORKS on F2/F3..USD
Okay I have been trying to research this for a while. I have a 94 F2. Swapping 98 USD GSXR forks. Read that the stem from the 98 GSXR needs to be milled down. Does it need to be milled down to match the diameter of the F2's or what portion needs to be milled down?
Old Dec 16, 2018 | 01:18 PM
Commander_Chaos's Avatar
Before I machined down a stem I'd look for a bearing that fits what you have. You're looking for a bearing with I.D. of the Suzuki stem and the O.D. of the Honda frame. All ***** racing has bearing kits for popular front end swaps and can also help you find sizes that aren't listed. Industrial bearing suppliers can also help.
If you end up having to do the machining route, you'll need a lathe that is large enough for the lower triple clamp to clear the bed. Otherwise, you'll have to press the stem out of the lower triple clamp, machine it, and press it back in. Stems typically have a machined place for the bearing at the bottom, a section of smaller diameter in the middle, a machine place for the top bearing, and then a threaded place for spanner nuts. The bearing surfaces will need to match the I.D. of the Honda bearing.
jmbiro2
F2 Tech
May 19, 2011 06:18 PM
rtabish
Jun 12, 2010 01:12 AM
paul6585
Sep 11, 2008 04:27 PM
bhhacker
Oct 29, 2007 03:31 PM
SpiritRR
Aug 30, 2007 11:44 AM
