Turn signal speed are different
Old Jan 14, 2007 | 08:41 PM
CYCDUP's Avatar
Default Turn signal speed are different
What causes the left side turn signalsto blink faster than the right side and what is the fix?
Old Jan 14, 2007 | 08:48 PM
D2VW14_20's Avatar
Default RE: Turn signal speed are different
Do you have aftermarket turns or have you dont anything to the turn signals??? If not, it sounds like there may be a short in the wiring somewere. It wont be a fuse, otherwise they wouldnt be working, so it sounds like a short or something.
You can use inline resistors to control the variation of speed.
Old Jan 14, 2007 | 11:33 PM
Vermino's Avatar
when i installed my alarm system in mine - i forgot one of my back turn signal's wires (i forgot to connect it) so my right side signal would blink 5 times per second were my left would only blink 1-2 per second. Dont know if you did any mods or not.
Old Jan 15, 2007 | 01:00 AM
knightslugger's Avatar
did you use different bulbs if they've been replaced (either by you or previous owner)? that may cause a drop in one side's amperage draw than the other.
Old Jan 15, 2007 | 02:20 PM
FATHEADS1KRR's Avatar
Or you just have a bulb out.
MrBlaze
Aug 17, 2009 02:07 AM
Cun0144
Sep 23, 2008 10:04 AM
BRRandon
Jul 27, 2008 04:56 PM
dwarfdwarf
Apr 25, 2008 08:52 PM
BadgerCBR
Apr 5, 2008 08:18 PM
