Shorty Stealth Exhaust 06 F4i help
I bought the shorty stealth motogp exhaust for my 06 f4i and it says that it does not fit the CBRs with the O2 sensor, but I figured I would just drill a hole and put it in there. Well I installed it and just let the O2 sensor hang on the side while i give it a spin with the new exhaust (sounds bad *** by the way), and it stops. The red light comes on, and the battery dies so it wont start. Overheated? Or do I just need to put the O2 sensor in the pipe? and if so, is there some kind of "metal glue" i could use to fix it in there instead of drilling threads in the pipe.
Thanks!
-rex
Thanks!
-rex
If it overheated it would have said so on the temp gauge. Were you not watching it? Red light is oil pressure I thought. You need to put the 02 back in and do it the correct way.
