question
Old Dec 30, 2006 | 03:57 AM
skimo0104's Avatar
Default question
i installed a pcIII usb to my 2006 cbr 600rr.. i got it mapped and it worked fine and now my bike is not turning on. what i thought was the tps i guess is not and according to the pictures it is not where it says that is should be.it seems to be above the throttle bodies by the air filter box... am i wrong or is it just a bad programmer??
Old Dec 30, 2006 | 03:01 PM
drprcbr's Avatar
Default RE: question
i dont have a RR, but a good friend of mine does and i think i remember him hooking his to a set of plugs that were lower (i.e. not right under the tank cover). i dont know if that is where you have yours hooked up, but i would try another set...
Old Dec 31, 2006 | 12:05 AM
fishnride's Avatar
I have an 05 600RR and recently installed my PCIII USB.
Sincethe bikeran and now doesn't, I'm thinking that you need to check your connection to the battery first. If that connection is correct then check the following:
The TPS can be accessed on the left-hand side of the bike (as you sit on it) - it's pain to get to so make sure your connections there are complete.
The injectors that your PCIII should be connected to are under the gas tank. If you didn't have to unbolt at least the two forward bolts on the tank and tilt it back then you installed the PCIII to the wrong injectors.If you failed to connect one cylinder improperly, the bike should run, but with a misfire.
If all else fails, check the fuses in the fuse block on the left side of the bike under the left fairing.
odano1988
Sep 15, 2015 07:26 AM
bammerman
Jun 12, 2010 12:32 PM
600f4iHUNTERDON-NJ
Oct 8, 2009 10:30 AM
sempul
Sep 11, 2009 09:38 PM
viva_brasil
Jun 9, 2008 04:38 AM
