Need help/suggestions with wiring
Old Aug 6, 2009 | 07:20 PM
GPCBR6's Avatar
Default Need help/suggestions with wiring
I have a 2006 CBR 600RR w/LED tail/turn signals...I am installing proton flushmounts up front. I purchased my bike w/the LED taillight already installed and although I have not checked, due to the blink rate (seems a bit fast) I don't believe they installed resistors. When I install the protons I'm not sure what to expect. I have heard that I will need resistors at one end or the other or a new flash relay (not really wanting to remove upper cowl). I also read that you can install a showchrome dual load equalizer to fix any potential flash problems. What's easiest, what's best? Also, where does the showchrome dual load equalizer get spliced in at? Please help!
Old Aug 7, 2009 | 03:00 AM
sUshI's Avatar
I have aftermarket blinkers front and back, and yea, they blink faster..thats it. I deal with that rather than tearing bike apart
Old Aug 8, 2009 | 05:45 AM
GPCBR6's Avatar
when i finish the install if all i have is a faster blink rate i can deal with that too...i'll find out in a couple days
Old Aug 10, 2009 | 05:47 PM
browningbuck's Avatar
hey if you go to www.tripageled.com you can get a new relay that plugs in under the seat that slows them back down to normal. tristan is a great guy and can make all your problems go away with a simple plug and play mod
Old Aug 11, 2009 | 02:09 PM
johnnyx's Avatar
What's easiest is ignore it. There are no laws governing blink rate, I don't know whey everyone is so up in arms about having slow blinkers.
Old Aug 11, 2009 | 03:39 PM
GPCBR6's Avatar
Default Signals
as far as the plug and play relay that only goes for '07 and above, on the '06 it is behind the left mid fairing...i can use the elfr-1 from customled.com, i just have to wire it in...as far as needing the slow blinkers...with this install (w/o new relay)the flash rate isn't fast, it's hyper...u can't really tell it is flashing and in order for anyone to see it while i am riding it has to be slowed down...i prefer the faster flash rate cuz it seems to be more noticeable...hyper is no good though...also as far as the problem with the proton signal not working, it seems the signal itself is defective...they are shipping me out another one...thanks for the input...i'll update when i get everything done
Old Aug 14, 2009 | 12:00 AM
GPCBR6's Avatar
got the relay from customled.com and got it installed....it fixed the hyper flash. now i am just waiting for the replacement signal from hightechspeed. there is a pretty good vid. on the install (relay)...just check "2005 cbr 600rr led blinker relay install" on youtube....i have an '06 cbr 600rr and the install is the exact same...wires and everything...nice clean install, no resistors...you should check it out if you're having issues with the hyper flash and want to avoid resistors
xocolleenox
Mar 16, 2012 09:52 AM
cppr900rr
Oct 24, 2009 12:56 PM
duececivic
Sep 21, 2009 08:09 PM
medders22
Apr 1, 2008 03:54 PM
mastice
Nov 26, 2005 04:37 AM
