mesh in rear cowl
Old Sep 4, 2006 | 04:00 AM
unomystilo's Avatar
Default mesh in rear cowl
any1 tried putting mesh in place of the vents on the rear cowl of their 600rr? tried searching for pictures but zip. i have no search button skills sorry
Old Sep 5, 2006 | 12:06 AM
D2VW14_20's Avatar
Default RE: mesh in rear cowl
No, but i am pretty sure it wouldnt be hard. I did it for the fron fairings, but the 1k has the mesh instead of the fake plastic, so it can be done.
Old Oct 19, 2006 | 06:51 AM
jonboy84's Avatar
Yeah, I did it to my 06 600 rr, it takes about 45 min that includes re-assemble, the original inserts are held on by two phillips head screws when you remove them the inserts pop out hand form the wire mesh and use the original clip you will see what I am talking about when you do this it will help keep the mesh down in place. Personally I preferd using a hot glue gun with all of the mesh on my bike because it will heat up to a higher melting point then a lot of the appoxies your hardware or auto parts store has and will flex also. Its a pretty easy job all in all, if you want me to post some pics of the end results I can.
makoshoemaker
F3 Wanted
Jul 7, 2011 01:40 PM
wxgsr77
Jun 13, 2007 11:31 AM
VALKYIE
Jun 3, 2007 03:13 AM
