LED signal not working
Old Jun 30, 2006 | 03:25 AM
Riding Red's Avatar
Default LED signal not working
I put on some LED turn signals and started to buy load equalizers but I decided I like the fast blink rate. However, only the right side and left side rear is working now. The left side front does not come on at all. Is this a normal equalizer problem for only one side to work or is there something wrong with the signal?
Old Jun 30, 2006 | 05:13 AM
pistonnrings's Avatar
Default RE: LED signal not working
That doesn't sound like a load issue to me. To be sure you could switch the fronts side to side and see if the problem is still there. When I went to mini stalks the loads changed, the blinkers go faster, but all four still worked fine.
GL
Adescendant
May 28, 2015 07:09 AM
pjrocco
Apr 23, 2010 01:38 AM
papo020
Nov 30, 2009 07:57 PM
edubbs
May 31, 2007 09:14 PM
RRorXX
Jan 16, 2007 12:23 AM
