Inverted Forks? Would like some info
Old Jan 19, 2008 | 12:52 PM
F4iFreak's Avatar
Default Inverted Forks? Would like some info
In short whats the big deal with inverted forks anyways?
Old Jan 19, 2008 | 01:16 PM
knightslugger's Avatar
Default RE: Inverted Forks? Would like some info
better internals.
Old Jan 19, 2008 | 01:24 PM
sixhundredrr's Avatar
ORIGINAL: knightslugger
better internals.
Could you upgrade the internals of non-inverted forks to the same caliber or better or is the benefit of being inverted much more than non-inverted?
Old Jan 19, 2008 | 01:49 PM
tollfree969's Avatar
Can someone explain what inverted forks are? I keep hearing about it but I can't figure it out.
Thanks
Old Jan 19, 2008 | 02:46 PM
isolated1523's Avatar
Retired Super Moderator
Inverted forks.....
Non-inverted forks...
-Adam
Old Jan 19, 2008 | 04:47 PM
klutch_r's Avatar
Different mass centralization, less unsprung weight, generally stiffer, better valving, most have radial mount brakes, and they just look cooler. I'm running a 1000RR front end on my F4i. One-finger stoppies, yeah!
Old Jan 20, 2008 | 09:36 AM
F4iFreak's Avatar
So has anybody done that swap in an 04-06 F4i?
Old Jan 20, 2008 | 10:17 AM
dhondarider's Avatar
ORIGINAL: F4iFreak
all years f4 and f4i . use cbr 929 or 954triple trees. upper and lower. use 929 or 954 forks. or 1000rr forks. but you need the brakes and rim from each bike as well. use 929 triples with a suzuki hayabusa front end as well. front end will slide right into the 929 triples.
Old Jan 20, 2008 | 10:43 AM
F4iFreak's Avatar
Hmm sounds like a good winter project for next year. Thanks
Old Mar 8, 2008 | 10:37 PM
babyboy70363's Avatar
If your going for the looks, then spend the money on the new front end. If your going for better handling, then get the stock forks reworked with better valves and set up your suspension for you.
subyman1440
Oct 9, 2012 07:28 AM
Stinkonia
Apr 23, 2012 08:39 AM
jkilby18
May 28, 2011 01:22 PM
jfunkRR
Apr 30, 2008 09:23 AM
leanmachine
Mar 30, 2006 10:19 AM
