what inverted forks will fit me f4
Old May 27, 2011 | 08:05 PM
jkilby18's Avatar
Default what inverted forks will fit me f4
im a short guy and ive lowered it quite a bit and on med to large bumps the front suspension bottoms out... i figure by converting to inverted forks that will fix the problem.. not i just need to find a setup that works... any help would be awsummm.. thanks guys in advance
Old May 27, 2011 | 09:33 PM
gotcbr's Avatar
W/ how low you have it lowered, what's to say that a dif setup won't bottom out as well?
Perhaps your fork tubes need servicing to increase proper rebound.
Old May 28, 2011 | 10:47 AM
jkilby18's Avatar
i lowered it about 2 inches.. thats the reason why the front is suspension is bottoming out against the lower tripple tree...not against the ground.. i should have mentioned that before hand .. with the inverted forks when the tubes get slid up to lower it it wont take away from the shock travel at all
Old May 28, 2011 | 01:22 PM
gotcbr's Avatar
Here's pics of an F4 w/ an '03 1000RR front end swap that I know of offhand...
There are others that have done swaps. You may want to do some searches to see what else you can find.
subyman1440
Oct 9, 2012 07:28 AM
SIRR1
Sep 17, 2008 06:06 PM
jfunkRR
Apr 30, 2008 09:23 AM
03954guy
May 25, 2006 01:45 AM
leanmachine
Mar 30, 2006 10:19 AM
