inverted forks
Old Apr 20, 2012 | 07:49 AM
Stinkonia's Avatar
Default inverted forks
hello all I have a 02 f4i with a 959 fork conversion, I do not the the handle bar turn radius need to complete the military requirements. does anyone know how to make the handlebars have full range of motion as the stock handlebars. I was just gonna grind the stops off the forks that bump the frame unless someone knows a different way
Old Apr 20, 2012 | 08:16 AM
jeffjones's Avatar
What is the turn radius needed?
I know when I did my test it was VERY close to full handlebar turn to turn.
Sportbikes don't have good turning radius's as it is, but I'm sure the fork change isn't making a huge difference. Maybe get to an empty parking lot and practice for a couple hours.
Old Apr 20, 2012 | 08:26 AM
Stinkonia's Avatar
Well turning isn't an issue while driving because leaning plays a factor but the damn military safety courses are at 5 miles an hour and requires the bars to touch the intake covers to complete it
Old Apr 20, 2012 | 12:42 PM
gotcbr's Avatar
I've never heard of that. Please produce documentation. The bars should NOT touch the covers.
Old Apr 20, 2012 | 01:07 PM
jeffjones's Avatar
That was pretty much the same as my MTO test.
There were 2 pylons 3.5ft apart and those sets of pylons were placed 15ft apart and you had to slalom around the outside of each pylon and that also has to be done around 5-7km/hr. On my CBR you practically went from full turn to full turn, I practiced for days but in the end I did it (Only 2 of 11 people passed that part and the other was on a CBR 125).
Practice and lots of it is your answer.
Its easier to ride fast then it is super slow.
Old Apr 20, 2012 | 05:24 PM
Stinkonia's Avatar
Default Inverted forks
Well it has been over a week and my account still is not approved so I can not post my pics can someone post pics of there bars at full turn so I can compare. Mine do not go far enough to even lock the bars
Old Apr 20, 2012 | 06:03 PM
jeffjones's Avatar
email the pics to mccall187@hotmail.com and I can post them for you.
Old Apr 20, 2012 | 08:25 PM
knonfs's Avatar
When doing the 600rr front end conversion you have to grind a portion of the steering stops. Once you do, you next hurdle will be the brake master hitting the fairing when turning the bars to the left, and/or the clip ons hitting the duct covers.
Old Apr 20, 2012 | 08:59 PM
jeffjones's Avatar
If your brake master is hitting the windscreen and clips on are hitting the airducts wouldn't that make the turning radius tighter then OEM?
Old Apr 21, 2012 | 06:45 AM
ozf4i's Avatar
Just grind down the stoppers it's what I had to do on my 1000rt front end
