Inverted Forks on an F4I?
Old Sep 30, 2007 | 08:25 PM
EvilJames's Avatar
Default Inverted Forks on an F4I?
Ok I have an 03 f4i and i like the new 05 inverted front forks. It looks as if the triple trees would mount up and thus making it possible to mount the rr front end on. but i have heard the steering stem might be a different size so that could cause some issue. Anyone else heard about someone doing this if has anyone done it?
Old Sep 30, 2007 | 08:32 PM
oodie's Avatar
February 2009 ROTM
Default RE: Inverted Forks on an F4I?
I don't know myself but have you ever think about using 929/954 forks?
Old Sep 30, 2007 | 10:08 PM
EvilJames's Avatar
are they inverted? if yes then no i have not thought about it but as long as the forks are inverted i could care less if it was from a bigger bike.
anyone else?
Old Oct 6, 2007 | 11:40 AM
Ace_f4i's Avatar
the 929/954 forks bolt directly on. you need to have the wheel and clipons though. Watch out if you use 929 though because you'll need a new spring. The stock rate is a progressive .71/mm i think which is way too low. i've been doing research on this too. have you heard anything about the bike handling better after the mod? like from someone that can push the bike pretty ****ing hard and not just a flat spot rider who goes in straight lines.
subyman1440
Oct 9, 2012 07:28 AM
jkilby18
May 28, 2011 01:22 PM
SIRR1
Sep 17, 2008 06:06 PM
jfunkRR
Apr 30, 2008 09:23 AM
leanmachine
Mar 30, 2006 10:19 AM
