having trouble removing the stock exhaust
Old 08-30-2007, 03:11 PM
terrible one's Avatar
Default having trouble removing the stock exhaust
i have everything unbolted but is there certain way to take off the old muffler/pipe? im trying to install the two bros exhaust and im following the instructions and when i came to removing the stock system it simply says "carefully remove the stock muffler/pipe"
is there a special way to do this other than just trying to muscle it over the stock cat and out the back end?
thanks
Old 08-30-2007, 04:50 PM
Default RE: having trouble removing the stock exhaust
i had to turn mine towards the outside of the bike before it would clear
be careful you dont scratch the swingarm
Old 08-30-2007, 05:29 PM
unbolt everything, take it off. simple.
that is if you've got all the fairings off.
Old 08-30-2007, 06:09 PM
everything in the rear is off that they told me to take off. but you have to get it over the cat and i need only another inch or so but there is no more room to move the pipe, ill try and move it sideways thanks
Old 08-30-2007, 06:34 PM
ooooooooh.... i know what your problem is now...
it's stamped right on your can...
TwoBrothers Racing
Old 08-30-2007, 06:49 PM
ORIGINAL: knightslugger
TwoBrothers Racing
BWAHAAHAHAHAHAHAHAHAHAHAHAH
Old 09-01-2007, 01:55 PM
ok wow i just figured out im retarded and didnt take off one bolt still holding the stock exhaust on.... so since im admitting to being an idiot i had another question.
do you re-use the stock exhaust gasket for the new pipe? it doesnt seem like the aftermarket pipe will slide over it but again im friggen dumb as hell right now so i could be wrong.
thanks
Old 09-01-2007, 02:27 PM
should fit unless you mangled it...
Dah_U
02-28-2013 10:00 AM
zellster
09-26-2011 09:39 PM
350z_and_CBR
04-14-2008 09:32 AM
bhhacker
06-12-2007 08:52 AM
Quick Reply: having trouble removing the stock exhaust
