having trouble removing the stock exhaust
i have everything unbolted but is there certain way to take off the old muffler/pipe? im trying to install the two bros exhaust and im following the instructions and when i came to removing the stock system it simply says "carefully remove the stock muffler/pipe"
is there a special way to do this other than just trying to muscle it over the stock cat and out the back end?
thanks
thanks
everything in the rear is off that they told me to take off. but you have to get it over the cat and i need only another inch or so but there is no more room to move the pipe, ill try and move it sideways thanks
ok wow i just figured out im retarded and didnt take off one bolt still holding the stock exhaust on.... so since im admitting to being an idiot i had another question.
do you re-use the stock exhaust gasket for the new pipe? it doesnt seem like the aftermarket pipe will slide over it but again im friggen dumb as hell right now so i could be wrong.
thanks
thanks
bhhacker
Jun 12, 2007 08:52 AM
