Frame Slider Mishap...
Old Oct 28, 2005 | 12:25 AM
patas75's Avatar
Default Frame Slider Mishap...
So I bought some motovationusa frame sliders and tried to install them using the instructions they had on their site. it looked straighforward only it's not so easy after having a couple of brews. Well long story short, the hole was off so I had to file it down to fit. The fairings fit now but I have about 1/8" - 1/4" gap depending on which side of the slider you look at. On the way home I started thinking about ways to cover it up and it hit me. I can take a piece of plastic and create a ring around the slider, only problem is I'm not sure where to get the plastic. It'll look kinda like the ring that's around the gas cap only around the slider. I think I have already seen such a ring but I'm not sure where. Do you any of you have any ideas as to where to get the ring or how to make it?
Thanks
Old Feb 22, 2006 | 10:13 PM
DThompson's Avatar
Default RE: Frame Slider Mishap...
Look on the forums about Frame Sliders. Someone else has done this exact thing and it came out really good.
Daniel Thompson
Old Feb 23, 2006 | 12:42 PM
Tahoe SC's Avatar
i have the answer you're looking for mang...
those nice rings to go around the slider...you can use furniture grommets for that!
like on desks where they cut a hole in it to let the wires run though...they put the plastic around the hole!
TADA!!!!!!!!!...now...go...do...
Old Feb 26, 2006 | 04:18 AM
Ssaba420's Avatar
Tahoe SC ur da MAN !![sm=hail.gif]
Old Feb 26, 2006 | 03:10 PM
nxfedlt1's Avatar
check out my photos.... go to home depot, they cost 1.35 or something, they are the rubber drain gasket for the tubs.
Old Feb 26, 2006 | 03:43 PM
Advert25's Avatar
wow thats a really good idea...those look very sharp!!! great idea.
Old Feb 26, 2006 | 08:35 PM
eteller's Avatar
Damn! I'm as accurate as a CNC machine with a dremmel after a 12-pack!! No really, I've screw up more than a few things that way myself! The next day your like pink flame paint job? what was I thinking!!!
Old Feb 26, 2006 | 10:38 PM
cjbettis's Avatar
ORIGINAL: nxfedlt1
great fix!!!! looks good
ArcticSummon
Jul 25, 2013 03:19 AM
f4itypeofguy
Aug 31, 2010 12:48 PM
kash
Oct 10, 2006 12:05 PM
Ssaba420
Jun 29, 2006 06:10 PM
MapJr
Apr 9, 2005 05:32 AM
