FRAME SLIDER
Old Aug 11, 2006 | 02:47 PM
kash's Avatar
Default FRAME SLIDER
I am installing my Vortex Frame Slider as we speak. On the left side (shorter bolt) I have no problem but on the right side (long bolt) when I removed the engine mount bolt I noticed that there is another fastener (a nut of some sort) in it which makes my slider not to sit properly on the frame and its stick out more than the other side. Should I remove this nut or better yet, am I allowed to removed this? Any feedback will be greatly apprecaited.
Dan
Old Aug 11, 2006 | 05:11 PM
Blackdog F4i's Avatar
Default RE: FRAME SLIDER
DO NOT move that "nut". That is your engine mount. You do not want to change the alignment of the engine in the chassis.
Are you sure that you have them on the right side? My Shogun sliders were machined differently for each side.
Old Aug 11, 2006 | 11:46 PM
bruha's Avatar
Just curious, what color pucks did you choose to go with the silver/red bike?
Old Aug 12, 2006 | 09:56 AM
kash's Avatar
Black Derlin from Vortex.
Old Aug 12, 2006 | 10:09 AM
kash's Avatar
I call the throttle side the rightside of the the bike. Is that correct? The Vortex Frame Sliders has 2 different size bobbins that holds the puck. One is bigger than the other (diameterwise) & this will only fit on the right side. It came with a longer bolt. I got the engine mount bolt off but there is a socket hex cap screw in it which is probably you are correct Blackdog F4i that this is an aligning sleeves for the engine mount & should not be remove. Thanks a lot for the info.
Dan
Old Oct 9, 2006 | 08:33 PM
flin0211's Avatar
I installed the same vortex slider on my 06 F4i yesterday. I had the same question too.
So, the right side of the slider will be a little bit longer than left side, is it right?
Old Oct 10, 2006 | 12:05 PM
2006f4ido's Avatar
yup right longer than left...............
ArcticSummon
Jul 25, 2013 03:19 AM
f4itypeofguy
Aug 31, 2010 12:48 PM
hoangky
Jul 1, 2008 10:12 PM
tribal600rr
Apr 14, 2008 10:16 AM
Ricepowered01
Oct 19, 2005 08:12 AM
