Exhaust cut out
Old Apr 24, 2012 | 06:45 PM
03rep's Avatar
Default Exhaust cut out
On the rr I would like a easy open pipe hole and easy close again so that the exhaust flows though the miffler my only idea is a drilled hole at a bend or on the under side with a nut welled over it to plug it back up with a bolt any others?
Old Apr 24, 2012 | 11:07 PM
nickp123's Avatar
do you mean you want a cut out that you can cover up so the exhaust will go out through your muffler as normal but then you can open it up and itll be like youre straight piped like some drag cars do like the qtp cut out?
http://cdn.tundraheadquarters.com/bl...Controller.jpg
and if so, is there a purpose?
Old Apr 25, 2012 | 08:05 PM
03rep's Avatar
Yes exactly we have big monthly bike meets and I have seen several strait pipe bike and kinda liked the sound but not for all the time and it also kills what little low end you already have
Old Apr 25, 2012 | 09:28 PM
nickp123's Avatar
ah yeah gotcha. Well you can just have a friend or a shop weld that inline with your midpipe and then hit the button and open and close it as you please. Or they make non electronic ones that look exactly the same but you just have a lever/cable that you have to open and close it manually with.
vanhaman
Aug 15, 2010 06:09 PM
tricksta1984
May 25, 2010 10:20 AM
whiteflash
Feb 4, 2009 07:49 PM
cammelo
Apr 3, 2006 04:02 PM
