blinker integrater
Old Mar 31, 2007 | 08:50 PM
Pyle's Avatar
Default blinker integrater
I put a blinker integrater on and now the blinkers blink fast when the brake lever is pulled. I am assuming I have to put on some resistors. What do I need to buy, and what wires do the resistors go on to slow them down?
Old Mar 31, 2007 | 08:59 PM
bindelsf2's Avatar
Default RE: blinker integrater
mine did the same, but i like it better because it catches the eye of people not paying attention better...
but i will check it out and try and get back to you..
Old Apr 1, 2007 | 03:22 AM
dragonium25's Avatar
You already answered your own question...
ORIGINAL: Pyle
It's not the wires that slow down the blink rate, it's the resistors. That's all you need.
Old Apr 1, 2007 | 06:55 AM
Blue Fox's Avatar
Retired Moderator
On any other bike, I would recommend changing the flasher relay with a variable-load one. That would be ideal.........but since the 600RR's have their damn flasher unit built-in to a circuit board, it now forces you to use resistors (which I HATE using).
If you do front and rear LED signals, usually the signals don't flash at all (like in my case). I had to wire in 2 resistors (1 on each side) just to get the signals to blink fast. (the fast blink really doesn't bother me too much). But the resistors do get damn hot, so mounting them in a place where it won't melt anything is a pretty aggravating experience. (which is the reason I'm peeved about not having an easily replaceable flasher relay to begin with).
I'm going to try to bypass the stock flasher with an an aftermarket variable load one, but I just need the time to tinker with it. I'll let everyone know if that's possible or not.
Old Apr 5, 2007 | 10:23 PM
morphiusrr's Avatar
i just hooked up the stock blinkers and tucked them under the seat and you can tape the lense if you don't want them to show, but those resistors suck they get really hot fast, but you do it whatever way you want
cbr600f4i13
Jan 7, 2012 10:03 AM
mr_santini
Mar 29, 2009 04:06 PM
jDeArMeAmNy4
Apr 22, 2008 11:17 PM
shongboy
May 9, 2006 01:18 AM
