Back Taillight out
Old Jul 13, 2010 | 12:46 AM
danl23880's Avatar
Default Back Taillight out
So a few days ago my tail light went out. I checked the fuses on the left side and took off fairing all fuses were good. I checked 1 fuse under the seat by the battery. This was a 30a fuse and it was fine. Where else would there be fuses on my bike to check. I own a 2006 cbr 600. I have an integrated back taillight. Is it possible the bulbs have burned out. I have no idea. Please help.
Old Jul 14, 2010 | 10:16 AM
danl23880's Avatar
anyone?
Old Jul 14, 2010 | 03:20 PM
tpgpz's Avatar
I would use a test light for the wiring. Mine looks like a screwdriver handle with a light bulb in it and an ice pick probe. It has a ground wire with an alligator clip on it. Connect that to ground and check the connector or wire for the signal. If I had to guess, something probably gave up on the board in the tail light or the wiring is grounding out. If you still have the original light, you might try hooking it up to see if the problem goes away. Sounds like you checked all the fuses.
CBRme
F3 Wanted
Jun 6, 2011 01:35 PM
fubbzie
Feb 7, 2010 07:01 PM
domon
Oct 3, 2007 10:42 AM
null84
Sep 29, 2007 09:40 PM
FSUJames
May 18, 2007 06:13 PM
