Taillight
Old Jan 10, 2006 | 12:51 PM
FSUJames's Avatar
Default Taillight
My back tailight dosent work. Only if i use the front brake it will come on..... other than that... the running light dosent come on and when i use the rear it dosent work either. Pretty dangerous since i ride alot at night. The tail light isnt stock either when i took off the seat to play with the wires it was all a custom job....if anyone knows how to fix this or if anyone can do it if you live by me i will glady pay $. I have no idea what to do...thinking if i take it somewhere it would cost me some big bucks.
Old Jan 10, 2006 | 01:04 PM
sctt's Avatar
Default RE: Taillight
Check the taillight switch on the rear brake master cylinder make sure it is making the connection
easy fix if that is what it is
Old Jan 10, 2006 | 02:20 PM
Custom900's Avatar
I agree with Sctt
Old Jan 10, 2006 | 02:53 PM
kamranh1's Avatar
sounds like you have two problems. the rear brake light problem seems to be as said above, related to the switch on the rear brake. on the running lights, are the other running lights on the bike working? (the amber front turn signals and the headlight) if not check your fuses. if so, there should be two individual wires running to each running light, toalling three wires going to each bulb including ground, brake and running lights. make sure all are connected. (if it is an aftermarket undertail with integrated turn signals there will be four). then hit the wires with a volt meter and make sure that you are getting juce at the right time.
Old Jan 10, 2006 | 05:14 PM
Truckie973's Avatar
i found out from blowing a couple fuses that the spedometer and turn signals are on the same fuse. I dont know how this info might help you just thought i would throw it out there
Old May 18, 2007 | 06:13 PM
FNQuickF2's Avatar
Thread resurection... Also, make sure the switch adjusting nut is screwed up far enough to trigger the switch...Pull up on the cable, screw the nut downward, push the cable back in the hole, then try to see if it's pulling enough to turn on the brakelight...
RB
prnguitar00
Mar 25, 2010 07:14 PM
tspills88
Jun 22, 2009 01:31 PM
B Marques
Apr 10, 2008 11:03 PM
Altephor
Apr 9, 2008 12:44 AM
