adjusting my valves
Old Feb 27, 2008 | 07:01 PM
c45's Avatar
c45
Default adjusting my valves
hey guys, i am adjusting my valves and was just wondering how you recomend taking the camchain off? thanks
Old Feb 27, 2008 | 08:31 PM
OKIEZAC's Avatar
Default RE: adjusting my valves
wish i could help..givin u a bump
Old Feb 28, 2008 | 06:22 AM
wellarmedCr@cker's Avatar
First remove cam chain guide, then remove the cam chain sprocket bolts and then the cam sprockets. Then just tie the chain off to the side with a piece of wire, you don't have to totally remove it unless you planning on replacing it. If you don't have a factory service manual I would recommend getting one before I would attempt this kind of job tho.
Old Feb 28, 2008 | 12:58 PM
c45's Avatar
c45
ok cool thanks for the help
Old Feb 28, 2008 | 07:07 PM
Tacoma25's Avatar
The manual will show you where the tick marks for the crankshaft are so that you disassemble in the correct position. That is always a good thing to know.
Old Feb 28, 2008 | 07:45 PM
ORIGINAL: Tacoma25
No ****, screw the timing up and your screwed.
Old Feb 28, 2008 | 08:39 PM
Doodie's Avatar
First. How many miles are on your bike and Second. YOur probably going to wish you hadn't because it's a pain in the *** getting them right. And I tell you this because even if you can hear them tapping a bit that doesn't mean you need them adjusted... 9 out of 10 bikes in my buddies shop that ask for a valve adjustment didn't need one.... Hope that helps
Old Feb 29, 2008 | 02:27 AM
c45's Avatar
c45
thanks guys ya after getting everything apart and just checking the clearances it looks like i dont need to pull the cams. so now im just putting everything back together. the bike is a 05 with 24k+ miles. thanks everyone for the help
stuffum07
Apr 6, 2012 08:09 AM
Rick619
Apr 29, 2009 07:32 PM
kentuckydiesel
Apr 12, 2008 12:18 PM
BigRed
Sep 7, 2007 03:29 PM
pinoyofmodesto
Sep 17, 2006 05:28 PM
