93 sprocket change
Does anybody have any part numbers for dropping one tooth in the front and adding 6 in the rear? 1993 cbr 600 f2 , It does not do wheelies at all right now!
[IMG]local://upfiles/3543/442EB7303FCC4B63B9FB22FDDAAD82CF.jpg[/IMG]
a little extreme with the +6 in the rear... wheelies is all you will do with that.
Contact Todd or Kim @ Cal-Sportbike and they can hook you up with the parts you need. The prices are good, just mention you found their link on this site and it might help you out a little.
You probably need some practice if you cant get the F2 up there. They WILL come up. As for the +6, that is a little extreme. At most get a +2 in back and drop 1 in front. I'm pretty sure that will still fit without changing that length of chain from stock.
Daniel Thompson
Daniel Thompson
bowtieboy42
F2 Tech
Jul 10, 2012 03:53 PM
