sprocket change
Old Mar 10, 2006 | 10:02 PM
lincsace's Avatar
Default sprocket change
I recently bought a 520 conversion kit with a 1 down in the front and up six in the rear my question is does all the plastic have to come off in order to replace the sprockets ? does any one have any pics off it?
Old Mar 10, 2006 | 11:22 PM
doncollins's Avatar
Retired Administrator
Default RE: sprocket change
what bike and what plastic are you talking about? you shouldn't have to remove ant plastic?
Old Mar 10, 2006 | 11:38 PM
ChrisMcD's Avatar
Retired Admin
ant = any LOL
Old Mar 11, 2006 | 07:34 AM
Anubis's Avatar
Reasonably easy to do, no body plastic needs to be removed, just rear wheel, and normally sprocket cover at the front.
Old Mar 12, 2006 | 10:36 AM
lincsace's Avatar
how do I go about jacking it up? it sounds stupid but I don't see any spot to get my jack under it , i have done sprocket changes befoe but it was on v-twin motor cycles.
Old Mar 12, 2006 | 01:06 PM
JeffRR's Avatar
Uh..... jack? Try a rear stand. When removing the slave cylinder to get to the front sprocket cover DO NOT BLEED THE CLUTCH!!!! I don't care what the manual says. Trust me.
Old Mar 12, 2006 | 01:10 PM
NINE2NINE's Avatar
Retired Mod
yes, use a rear stand. there is nowhere to use a jack. and no body pieces need to be removed.
-1/+6 huh? that's insane!
Old Mar 12, 2006 | 10:37 PM
929_erion's Avatar
little high???
ORIGINAL: NINE2NINE
Old Mar 13, 2006 | 11:14 PM
lincsace's Avatar
I am a little insane , but I like it, where do I get a stand? how do I correct the speedo?
Old Mar 14, 2006 | 01:50 AM
scotty8583's Avatar
Sounds like you are planning on doing around 10mph in first gear with a change like that!!!!! Been on many sportbikes?
