600 to 1000 conversion
Old Dec 12, 2007 | 11:08 PM
wheelie_chris's Avatar
Default 600 to 1000 conversion
I searched couldn't find anything maybe I missed something but, Does anyone know if it is possible to put a 1000 engine in a 600rr like what I need to change etc...
Old Dec 13, 2007 | 09:09 AM
1993CBR's Avatar
Default RE: 600 to 1000 conversion
buy a 1000rr it's cheaper
Old Dec 13, 2007 | 09:27 AM
its actually not my friend wrecked his 1000 bad sold parts off it and i took the frame and engine off his hands for $300 and the other cbr I have the engine is blown on it. so it all works out. i know it possible just need to find the info. trying to look for it as i post this comment.
Old Dec 13, 2007 | 11:13 AM
Jason748's Avatar
I would still be cheaper to buy a 1000rr. You'd have to custom make, fabricateor buy SO many parts, even if you used 1000rr frame you'll come out behind what you would just picking up a cheap 1000rr.
Old Dec 13, 2007 | 02:48 PM
Jaybird180's Avatar
But isn't the point of this forum to do wild and crazy stuff like this??????
Old Dec 13, 2007 | 03:32 PM
ORIGINAL: Jason748
ok so you are telling me its going to take more than 8,000 dollars to do this conversion? the 1000 is an 06 so is my 600 it cant cost more then 2,000 dollars. 3,000 max and still come out winning because them bike cost over 10 grand... i have 4 bikes
91 honda cbr600 F2
05 honda cbr600
06 honda cbr600 blown engine (actually took it off my cousin for less then 2 thousand)
06 honda cbr1000 frame and engine only
Old Dec 13, 2007 | 04:32 PM
Jason748's Avatar
To do it the right way I'd say around $4000 - $5000 all said & done with the little issues worked out or maybe $2000 - $3000 if you have full access to a machine & fab shop, add that to the $2000 you already spent on the 600rr. And this time of the year you can pick up a nice 06-07 1000rr for between $6000 - $7000 if you're patient and you'll be ready to go. But you should be able to find a good 600rr motor that will drop in for $500 - $1000.Thenyou should be able to sell the 1000rr motor for about the same and the frame for another$500 or so. You tell me which will be cheaper in the end? I've done enough motor conversion in the past ten years to know that with modern frames, it not just as simple as making a couple of motor adaptor plates, welding them in and bolting the new motor in.
Now if you said you were doing itjust because &costs be damned then I'd be saying go for it.
Old Dec 13, 2007 | 05:26 PM
baxsom's Avatar
IF every single frame hole bolted up the same place
and the engine dimensions were the same
and the ecu and wiring harness and all the sensors were the same
it would bolt in
it was like putting the zx9 motors in a zx7
that supposedly wasnt that hard because the only thing that was different was the engine pistons.
now with our bikes every place that the mounting points are different you are going to have to spend the money to do the R&D, engineering, and fabrication of a bracket that not only fits but is strong enough to hold everything up.
i have both bikes. the dimensions are way too different
but with enough money and know how anything is possible
Old Dec 13, 2007 | 07:41 PM
03yellow6000RR's Avatar
There's an engine in this thread. If its not already sold.
https://cbrforum.com/m_429193/tm.htm
Old Dec 14, 2007 | 07:05 AM
fishfryer527's Avatar
Anything is possible, but not everything that is possible is practical. Go buy a literbike if that is what you want.
