11k drop-off
Old May 7, 2006 | 11:42 PM
Yellowjacket's Avatar
Default 11k drop-off
Hey guys I need HELP bad.
I have a 2003 600RR it tops out at 15k, or it did!!
I top out at 11k and the R,s just drop off!!
I had a code 11 (speed sensor) in the module & I cleared it
I still have the problem,
Has anybody had this issue before???
thanks
Yellowjacket
Old May 12, 2006 | 08:14 AM
Air4Andy's Avatar
Default RE: 11k drop-off
How is the bike running? Sputtering, anything? Does it just feel like you are hitting the rev-limiter but it's f'ed up somehow, or does the bike spit and struggle to go more? Details...
Old May 12, 2006 | 07:24 PM
Hey there,
The bike runs & idles normal, you can crank it through the gears but just as you hit 11k she falls on her face & the mil lamp comes on, normally you just shift quick & keep going. I have not tried waiting to see what happens after she dies out or when she'll take off again in the same gear. I still have no codes after this happens, I'm going the recheck my fuel lines.
thanks
Yellowjacket
Old May 16, 2006 | 02:15 AM
sodamninsane's Avatar
sounds like the fuel system isn't keeping up with the load. fuel filter maybe?? you still have bad gas in it from the winter? that is the first thing I would check. then maybe the electrical, but it if idles normal it's probably not that.
YiNYaNg
Nov 30, 2009 05:48 PM
jeremynguyen216
Apr 14, 2009 03:39 AM
stevecb1981
Mar 30, 2008 01:49 PM
Kikepiz
Nov 17, 2007 01:54 PM
jaynd
Jul 19, 2007 12:16 PM
