11k drop-off
Hey guys I need HELP bad.
I have a 2003 600RR it tops out at 15k, or it did!!
I top out at 11k and the R,s just drop off!!
I had a code 11 (speed sensor) in the module & I cleared it
I still have the problem,
Has anybody had this issue before???
thanks
Yellowjacket
thanks
Yellowjacket
Hey there,
The bike runs & idles normal, you can crank it through the gears but just as you hit 11k she falls on her face & the mil lamp comes on, normally you just shift quick & keep going. I have not tried waiting to see what happens after she dies out or when she'll take off again in the same gear. I still have no codes after this happens, I'm going the recheck my fuel lines.
thanks
Yellowjacket
thanks
Yellowjacket
sounds like the fuel system isn't keeping up with the load. fuel filter maybe?? you still have bad gas in it from the winter? that is the first thing I would check. then maybe the electrical, but it if idles normal it's probably not that.
