Sprocket ?
Old Sep 18, 2006 | 12:45 PM
Zain's Avatar
Default Sprocket ?
hey all new to the forum but i'm sure i'll be asking alot of question in the future. need a little help with a sprocket question, about two weeks ago i picked up a 04 1Krr.
noticed that the speedo was about 15 miles and our off at 55. got to looking and the rear sprocket has been changed to a 41 tooth. the shop were i bought this neglected to inform me of this. my question is haw can i determine how many miles are actually on the bike. thanks for your input.
Old Sep 18, 2006 | 03:06 PM
MgA_ODEN's Avatar
Default RE: Sprocket ?
Stock sprocket sizes are 16/41 (on US spec 04-05 bikes)
gearing calculator
Old Sep 18, 2006 | 07:12 PM
Zain's Avatar
really everything i've been able to find tells me that it should be an 40 tooth. even so what else would cause the speedo to be off by so much.
Old Sep 18, 2006 | 09:34 PM
baxsom's Avatar
all speedos are off
when you change the gearing it is off by even more
when i put my 06 on the dyno the bike speedo read 185 at 6th gear redline
the dyno red 174
you have to get a speedohealer and then figure out by what percentage the bike speedo is off to make it read correctly
US spec bikes are 16/40 unless it is an 06
then it is a 16/41
the 04/05 euro bikes were 16/40
Old Sep 19, 2006 | 01:44 AM
MgA_ODEN's Avatar
ORIGINAL: baxsom
then it is a 16/41
US spec bikes are 16/41 unless it is an 06
then it is a 16/42
Old Sep 19, 2006 | 05:05 AM
chainstretcher's Avatar
Admin Emeritus & MVN
Ya, stock for '04 - '05 is 16/41. But if your speedo is off 15mph at 55mph then something ain't right. I mean 5%-12% error for a bike speedo is almost expected but you're talking almost 30% off. Are you sure it doesn't have a 15/42 on it? No matter really, the best way to correct it is with a speedo healer -- easy install and set-up.
Old Sep 21, 2006 | 12:17 PM
Zain's Avatar
turns out that there is a recall on 04 speedo's, goes in next week to be replaced. hopefully that should fix it.
Old Sep 21, 2006 | 01:18 PM
Rampage's Avatar
thanks, just call and scheduled mine too, I was very close on buying a speedo healer too.
Old Sep 21, 2006 | 08:55 PM
baxsom's Avatar
ORIGINAL: MgA_ODEN
ORIGINAL: baxsom
then it is a 16/41
then it is a 16/42
my bad you are right i typod the US spec
Old Sep 21, 2006 | 08:56 PM
baxsom's Avatar
ORIGINAL: Rampage
its still a good idea, especially with a tooth change
when i had mine dynoed it was 15mph off on the top end compared to the dyno
Myfirstcbr
Mar 22, 2013 09:40 AM
DunnRR
Jun 10, 2010 02:31 PM
