Shorter front fork???
Old Apr 4, 2008 | 10:18 PM
roderickdj's Avatar
Default Shorter front fork???
I know everyone hates it when they hear about someone wanting to lower there bike im well aware of all the side affects to it already but when lowering the front end you must slide the triple tree down on the front fork...i dont know if its possible or not but could you buy a shorter set of front forks that wouldnt have the inch or whatever sticking up and out of the triple tree? also to prevent from the front end smacking down on the front hugger and marking it up if it could be made stiffer? if anyone knows if this is possible please let me know, thanks
Old Apr 5, 2008 | 11:46 AM
Volksdragg's Avatar
Default RE: Shorter front fork???
I doubt anyone makes shorter forks, but what you could try is to exchange your springs in the forks too a stiffer one and go with a little heavier weight oil in them. Then you should be able to lower your forks.
bananazx
May 14, 2008 04:50 AM
WhiteCarbon
Apr 13, 2007 09:08 PM
Turnin20s
Apr 18, 2006 02:06 PM
transamlt1man
Mar 29, 2006 02:29 AM
excidium28
Aug 28, 2005 04:51 PM
