Rear fender cut-down
Old Apr 3, 2006 | 09:56 AM
rogfog's Avatar
Default Rear fender cut-down
Now fitted my "modified" rear fender which will look OK until I can afford a new exhaust system for the bike!
Just used a dremel to remove most of the unsightly plastic, removed the original licence plate light and replaced it with a small LED unit (Motrax).
Then replaced stock indicators with LED arrows (fitted with resistors initially but now under the control of a new relay).
Looks OK from the back - bit rough around the edges but not too bad if you don't look too hard.
Didn't cost me anything apart from the plate light and I already had the LED indicators from a previous bike.
Just another "solution" to the hideous snow-shovel that these come fitted with.
[IMG]local://upfiles/2705/6312A8CE62CA47D7A43AB102C19A7F8B.jpg[/IMG]
[IMG]local://upfiles/2705/D5E3ED2415E54ADE9BDF5809772031AD.jpg[/IMG]
[IMG]local://upfiles/2705/6AE95D297C64462990044CC77B6036DB.jpg[/IMG]
Old Apr 3, 2006 | 02:53 PM
RR RIDER's Avatar
Default RE: Rear fender cut-down
Looks good real clean! nice job
Old Apr 13, 2006 | 03:23 AM
STRICKN's Avatar
Looks real good.
Old Apr 13, 2006 | 04:14 PM
RedRider79's Avatar
not bad
Old Apr 14, 2006 | 01:06 PM
wheelieit's Avatar
This is a cut down I did literally. I have not bought anything yet. All this takes is a little time and patience trying to undo what Honda has done back there. I plan on making my own plate mount with light. It will be tight. I'll post when done.
[IMG][/IMG]
Old Apr 14, 2006 | 01:15 PM
wheelieit's Avatar
Sorry, I'm still getting the hang of all this.
[IMG][/IMG]
[IMG]local://upfiles/6461/F724D9651D2D43558FAF1978843E38CD.jpg[/IMG]
[IMG]local://upfiles/6461/A2E5944F0E5F4C03BE0DF5D1CE28ABCB.jpg[/IMG]
madgreek
Aug 8, 2007 02:23 AM
aaron1085
Mar 18, 2007 04:15 PM
