Power Commander quesiton
Old Jan 3, 2009 | 08:36 PM
gary86's Avatar
Default Power Commander quesiton
i traded my 07 750 for a 07 1000rr and it came wth a power commander...my question is; is there a webste or something that tells me how to tune it to how i would like it?
Old Jan 4, 2009 | 12:38 AM
WONTnevaCATCHme's Avatar
Default RE: Power Commander quesiton
you can get custom maps from the exhaust company if you have an aftermarket exhaust if not look up the companys website on the pc111, they usaually have maps to download. You will really only realize a differance f there is other mods like filter and exhaust.
Old Jan 5, 2009 | 03:21 PM
johnny444's Avatar
Download a map that closest matches your setup from http://www.powercommander.com/powerc...44&yr=2007for free or get a custom map made for ~$300.
Old Jan 8, 2009 | 11:05 AM
hemigoat2003's Avatar
Pardon me for jumping in, but i've got a few questions along the same lines as Gary 86.
If i buy a Dyno Jet PCIII, does it come with a generic map for my 07 1krr, or do i have to specify which map i want. If i re-map it with stock exhaust, and later add aftermarket exhaust, is it fairly simple to re-map? Do their downloadable maps get me fairly close, or will i need to get it dyno tuned to really make a difference? How much do the downloadable maps cost?
Thanks for any info. As you can tell i'm a newbie when it comes to the aftermarket for these bikes.
Old Jan 8, 2009 | 03:46 PM
johnny444's Avatar
ORIGINAL: hemigoat2003
It is sold with a map made for a stock bike.
Yes. PC III USB uses a USB cable and a 9v battery adapter to plug the PC III into your computer and download the map.
Yes the powercommander.com maps will get you very close but if you want it "perfect" for your bike (pipe, filter, etc.) you'd have to get a custom map done for ~$300 or you can alsotry a custom map from a database of custom maps that guys have made available over on 1000rr.net.
Free.
No problem.
Old Jan 8, 2009 | 07:02 PM
dwschultzy's Avatar
pretty much what johnny said.....
i would strongly recommend doing filters and an exhaust with the pcIII....get a custom map done at the same time.....otherwise you will not notice much but a slight bit of smoother throttle response.....downloadable maps are good....but nothing beats a good custom map....make sure you check around your area for the "best" map programmer....otherwise you could just be getting something a little different than a downloadable one
Old Jan 9, 2009 | 10:26 AM
The closest dyno to my location is 6 hrs away in the Dallas / Ft. Worth area. The elevation there is much closer to sea level than it is here in West Texas. There is a noticeable power increase when i ride my bike in Dallas, as compared to here. Will that affect my tuning? If they tune it to the optimal levels in Dallas, will my bike still perform at optimal levels back home?
Just curious.
Old Jan 9, 2009 | 01:19 PM
johnny444's Avatar
It would be optimal to get the map done at or near the same altitude as where you live.
Have you searched on the powercommander site using your zip code?
http://www.powercommander.com/powerc...px?State=Texas
If possible you want to use a place that has the tuning link software.
Karmakazi
Sep 29, 2009 09:58 AM
joe-4422
Apr 7, 2009 09:47 AM
jfunkRR
Feb 19, 2008 03:10 AM
JROD19
Aug 10, 2006 09:37 AM
maxwell139
May 16, 2006 01:30 AM
