plate lights
Old Aug 8, 2006 | 10:05 PM
cande17's Avatar
Default plate lights
hey i was wondering what everyone is doing for plate lights after putting a fender eliminator. I know about the lighted plate frames and i know about the led plate bolt lights.. i have a buddy that got some led plate bolt lights that have a built in battery so there is no wires.. my uncle has a zx14 and he got the competition werks kit with the plate light that sticks to his undertail but of course i can't stick a light to my exhaust soo.. let me know if you have any suggestions!! thanks alot
Old Aug 9, 2006 | 12:13 AM
MgA_ODEN's Avatar
Default RE: plate lights
ORIGINAL: cande17
Whats your question?
Old Aug 9, 2006 | 12:36 AM
baxsom's Avatar
this is what I use
http://www.cyclegear.com/spgm.cfm?L1...em=DEN_30301_G
Old Aug 9, 2006 | 02:22 AM
dirtysport's Avatar
This is what I am going to use. It comes with the license plate light and 2 blinkers, but I am not going to use them. I am going to go with the tail light/blinker kit all in one.
http://www.competitionwerkes.com/ima...2LTD-HiRez.jpg
Old Aug 9, 2006 | 11:13 PM
mannyrios's Avatar
baxsom-> Nice.. how does the LIGHT N' BOLTZ LICENSE PLATE? Work? Would I need to run wires to make it go on... or is it battery operated? Is it a difficult install? Thanks!
[hr]
Old Aug 10, 2006 | 01:18 AM
recker's Avatar
I too am looking for a good plate light, the one above is good but i also would like to know how it works
Old Aug 11, 2006 | 01:32 AM
baxsom's Avatar
you cut the plug off of your oem light
each bolt has 2 wires
you put 1 wire from each bolt to 1 wire from the harness
basically splitting the harness wires in two and both + and ground wire to the bolts
Old Aug 11, 2006 | 06:02 PM
King James's Avatar
If you get the competition werkes kit it comes with a light for the plate.
Old Aug 14, 2006 | 06:31 AM
silentsamurai's Avatar
CW fender elim. STD i believe it was.
It keeps the plate at the rear. and uses the stock rear turn sigs and stock plate light in the middle of your turn signals (little lump between the turn sigs on the metal bracket)
Old Aug 14, 2006 | 08:46 AM
baxsom's Avatar
yeah but the whole idea is to get rid of all that plastic
i use Larrys FE kit which is just a plate bracket under the band holding the arata to the tail
wires are tucked away for the plate light bolts and the turn signals are short stalk minis attached to the bracket where the rear red reflectors used to be
03cbr6
Sep 1, 2011 10:21 PM
03cbr6
Aug 31, 2011 01:00 AM
thegreenbandit
Aug 29, 2009 01:47 PM
dragginazz
Jan 28, 2009 02:24 PM
FNQuickF2
Feb 16, 2008 12:26 AM
